Buying an ATV Questions and suggestions about what to buy, financing, insurance, etc.
DMV Inspection Requirements?
Old Jun 4, 2011 | 10:28 AM
Kedonot1's Avatar
Default DMV Inspection Requirements?
What do they usually inspect? Do they test-drive?
Because, my ATV is fine. Expect the clutch gets stuck sometimes on reverse. I need new back break pads and break cord. Also I need new tires.. my back ones have cracks, cuts, slits, or whatever in them.
Lemme know asap.
Old Jun 7, 2011 | 11:30 AM
atvqrt's Avatar
Default DMV requirements
You also want to check your Lights out- Head lights and tail lights and brake lights. DOT is also watching for proper tiedown. Looks like everything is moving toward Tire Traps, ATV Mighty TiTes or Louisiana guard dog. If not a system like these designed for transporting, you better have 4 tiedown straps each capable of 1000 lbs strength. Using the winches to tiedown is also on the way out. Too many have stripped to gears and had releases.
Old Jun 7, 2011 | 12:26 PM
mudslinger2's Avatar
I haven't been stuck since the last time!
Default Visual lookover
Lemme know asap.
I have found that it is just a visual check...lights, muffler, brakes, taillight! They will also check the vin to make sure that it is there!
Old Jun 7, 2011 | 02:47 PM
Kedonot1's Avatar
Yeah. Do they check if they are operating? Because my back one is seized.. Doesn't have pads.. And, im not sure if my vin number is on my four wheeler anymore. :P It's old. My muffler is also rusted out kinda.. but i think it should pass.
Old Jun 7, 2011 | 02:49 PM
scootergptx's Avatar
Supersock
Hired Gun!
Are trying to get it inspected for the road? Honestly it doesn't sound safe for a trail.
Old Jun 7, 2011 | 02:55 PM
Kedonot1's Avatar
I have front breaks, and a winch. And the break isn't seized, the cable is seized. I bought a four wheeler from a moron and he put the brake cord right on the muffler it melted and rusted out causing it to seize.. than the brake pads weared out and ruinde the whole brake system. I'm probably going to fix it..
Old Jun 7, 2011 | 03:47 PM
Red400EXRod's Avatar
Pirate Biker
Limping Rider!
You bought the quad from a moron????
You actually paid money for this POS???
Old Jun 7, 2011 | 04:07 PM
Kedonot1's Avatar
It moved.. and it's not that bad..
It was only $400. -.- He wanted 950. I got him to say 400.
ltrmc02
Aug 22, 2021 02:34 PM
Joe454
Nov 20, 2020 01:19 PM
BYC
Sep 25, 2015 02:10 PM
cboler9
Sep 24, 2015 08:35 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
