CAN-AM (BRP) Ask an Expert! An area where experts in their field will answer Non-General or Non-Basic questions about your CAN-AM (BRP) ATV. ASK ALL GENERAL QUESTIONS OR BASIC QUESTIONS IN THE CAN-AM (BRP) SECTION. Basic or General questions posted in a expert section will be moved!
MrHorsepower and other experts will answer your questions as they have time.
OMW Big-Bore Cylinder vs. Sleeve Kit
Old Jul 8, 2009 | 11:30 PM
scrambler400enoge's Avatar
Shapeshifter Rider
Originally Posted by ROD2009
what cc would a 105 cylinder be on a ds650 what would one run like in 300ft dirt drags?
730cc.
Old Jul 9, 2009 | 07:03 AM
ROD2009's Avatar
how do you get a 725cc then just wondering? thanks for your info.
Old Jul 9, 2009 | 07:25 AM
THEBOM's Avatar
THEBOM Racing. If it don't scare you a little, it's not going fast enough !!!
A 650 with a 105.5 cylinder bolted on is 725.56 cc
Some times they get rounded up bigger.
I have built some and they have done very good. One in race trim and in an oem frame ran 4.19 in 300ft. This is the fastest 725/730cc I have hear of.
Old Jul 9, 2009 | 09:12 AM
ROD2009's Avatar
I was on a business trip down in southwest VA and i stop at a track in LPR Raceway and saw a ds 650 in a stock frame with nos run low 20s back to back i think that they where a father and son race team but they sure knew what was going on i think they said it was a 725cc that was why i was wanting to know. it was strong for sure did not get a name or nothing. thanks bom for the info.
Old Jul 13, 2009 | 11:33 AM
  #15
ROD2009's Avatar
bom someone said that you do a 760 motor what do this run like in 300ft i think eric does a 770 what is the difference i am going to start this dragracing before to long and i am likeing the ds650s. thanks
Old Jul 13, 2009 | 12:25 PM
  #16
THEBOM's Avatar
The difference between a 760 and 770 is 1mm in stroke. I can do a 770 but I have the pistons already set for the 760. The 760 is a 4mm stroke and makes more torque than the 650/725s earlier in the power range. This will get you moving faster and pulling longer than the smaller motors. But even with lots of power , you have to have the set up to make it work.
Me and Mr HP has our own ways to make power. Don't mix and match our parts. They don't work well together.
Dewhound
Apr 20, 2017 02:25 PM
Jaymc
Sep 11, 2015 07:45 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
