CAN-AM (BRP) Ask an Expert! An area where experts in their field will answer Non-General or Non-Basic questions about your CAN-AM (BRP) ATV. ASK ALL GENERAL QUESTIONS OR BASIC QUESTIONS IN THE CAN-AM (BRP) SECTION. Basic or General questions posted in a expert section will be moved!
MrHorsepower and other experts will answer your questions as they have time.
need help
Old May 13, 2010 | 09:12 PM
BBR650's Avatar
Is always changing bikes.
[QUOTE=OMR;2925355]I have had cdi go bad, but not intermittant.
Cdi's either work or fail.
On cars the coils will sometimes fail at a high rpm under load.[/QUOTE
OMR this is probably the only time i will ever do this.....lol false, cdi can work and not be dead. i had this issue with my vortex. bike ran fine last fall. refreshed top end, bike would not start kept back firing. cam/crank timing was on. vortex firing. started paying close attention while watching plug fire and timing between compression and plug seemed odd. put the rwr on it fired right off. the vortex was firing on the exhaust stroke. how this has happend i have no clue. i am going to have jeff send it off and have it checked out to see if it can be fixed as i need it for nitrous.
Old May 13, 2010 | 09:56 PM
OMR's Avatar
OMR
Is Oldmanracing! Also the inventor on the DS650 carb Mod!
If I recall the DS is setup to fire on both compression and exhaust.
The Vortex firing only on exhaust is weird.
Live and learn.
I bet your getting anxious to get that beast of yours on the track.
OMR
Old May 13, 2010 | 10:51 PM
lanerholloway's Avatar
fix the problem it was the inline fuel filter. but was wondering how high my big gun rev box let the rpm go up too
