CAN-AM (BRP) Ask an Expert! An area where experts in their field will answer Non-General or Non-Basic questions about your CAN-AM (BRP) ATV. ASK ALL GENERAL QUESTIONS OR BASIC QUESTIONS IN THE CAN-AM (BRP) SECTION. Basic or General questions posted in a expert section will be moved!
MrHorsepower and other experts will answer your questions as they have time.
Ds250 Missfire
Old Aug 13, 2012 | 07:14 AM
lazerles's Avatar
Default Ds250 Missfire
Hi have just purchased a second hand 2007 ds 250 am trying to sort out a electrical fault it starts perfect idles fine but as soon as you try to accelerate it misfires. Have done the carb new plug new cap strangely enough after doing all of that it fired no problem with no misfire turned it on and off a few times restarted it thought i had sorted it started it later... misfire back.Also replaced the battery at the same time.Have put a timing light on and the spark breaks down just after quarter throttle so sure its electrical.Any help would be appreciated thanks.
Old Aug 13, 2012 | 07:21 AM
scootergptx's Avatar
Supersock
Hired Gun!
Welcome to the forums.
So the spark plug wire looks good? No arcing off of it?
Old Aug 13, 2012 | 07:30 AM
lazerles's Avatar
Plug lead looks good will start in the dark and see if a i can see any arcing.Thanks for the reply.
Old Aug 13, 2012 | 08:33 AM
lazerles's Avatar
Hiya would you know if it has high and low speed coils in the stator it almost feels as if it is hitting a rev limiter.
Old Aug 13, 2012 | 08:40 AM
Supersock
Hired Gun!
Don't have the manual with me here at work. I know my 06 was a SYM atv that was rebadged as a BRP/ Can Am. May want to look and see if you can find a manual online for it.
Old Aug 13, 2012 | 08:46 AM
lazerles's Avatar
Hi thanks for the reply did manage to find a manual it is a sym manual seems close to what i have have got all the electrical testing values so will start with them.Does not show a reverse over ride though not sure if that is causing the problem problem.
Old Aug 13, 2012 | 08:47 AM
Supersock
Hired Gun!
That is tied into the cdi, so could be part of the rev limiter issues you're talking about too.
Old Aug 13, 2012 | 09:08 AM
lazerles's Avatar
Thanks will test all the values tomorrow and let you know. Unfortunately don't know any one with the same quad otherwise could just swop over the cdi. Thanks for your help much appreciated.
Old Aug 16, 2012 | 12:29 AM
lazerles's Avatar
Managed to sort out my misfire problem it was the cdi managed to get a new one off a big boy scooter for $25.00 compared to what the agents wanted $260.00 only a 6 pin left off the reverse limiter wire.Thanks to a fellow member on the site who helped me get it sorted
thanks Koos Meyer.Sure way to tell if the cdi is blown look on the back will see a small raised section were it has blown through.
whosgotmyback
1) Engine problems..
Jul 12, 2010 08:22 AM
magnum350
Apr 27, 2010 01:01 PM
mbarryracing
Feb 4, 2010 10:24 AM
notsedsnoyl
Jan 5, 2008 04:59 PM
latravcha
Nov 7, 2005 12:36 AM
