HOW MUCH DOES A 44mm LECTRON RUN????
im looking to buy one new and was wondering what they list.iv got a TM45mm im getting rid of with maybe two gallons gas through it since it was new,i just cant figure it out so im going to the 44mm lectron.im putting it in the personals but need to know what would be a fair price?
I think you should look at the Lectron 46 High Velocity Carb. I guess it works like the 42 on the bottom and the 46 on top. It suposedly has NO low end stumble.. They run $450. You need the ported intake for the 46..
I bought my Lectron 44 new for $240.00. That was already set up for my bike and jetted with additional jets and shipping.
Email Kevin at Lectroncarbs@aol.com
Frist the lectrn is not better than the 45 no way not even a fair comparision but the lectron is easy to tune and is as good on alachol and ive seen some pretty cheap lectrons on Ebay good luck !!!
have yall had any experience with a 45 on a predator? i am looking for a bigger carb to run on alcohol where can i find one
JMiller
On a percen.tage level i would say its 20% better when tuned right it is just smoother pulling and i belive it pulls longer and harder all the way threw!!! and it is less tempermental to alltitude changes[img]i/expressions/face-icon-small-confused.gif[/img]but the lectron i belive is a better alcahol carb due to its simplicity and plastic bowl!! and it is easy'er to tune too[img]i/expressions/face-icon-small-happy.gif[/img]good luck with your decision!!
good info.
Predator530,
I think the TM42mm woulsd be the perfect carb for the predator, I have seen some modified DS's run VERY well withy this carb, so i would think with your mods your preditor would be perfect also. The 45mm would be alittle much for you dissplacement, not sayig that it wouldnt work, just the 42mm would work better. IMHO
BIgger.
Predator530,
BIgger.
