When to get the shimm under bucket??
Old May 27, 2003 | 07:56 PM
MudStud's Avatar
Default When to get the shimm under bucket??
Web cam says anything over .400 lift...
Well RW says the a1 and a2 .433 & .406 DONT need the conversion kit??
Old May 27, 2003 | 08:00 PM
BillDS650's Avatar
PAMI, WEB CAMS, Sam Coe
Old May 27, 2003 | 08:03 PM
MudStud's Avatar
what do you mean??
ONLY those brands??
So the run woods a1/a2 dont need them??
Old May 27, 2003 | 09:38 PM
BillDS650's Avatar
You can get shimm under bucket kits from PAMI or Web Cam's Sam Coe sells the Web cams one. They will work with any set of cams and are a must for high RPM. The hard part is finding the shims. I had to have my valve stems tiped.
Old May 27, 2003 | 10:04 PM
KenDS's Avatar
MudStud,
Save your money... you don't need shim under bucket. If you puke a shim at the RPMs that you will be running it will be because the set-up was wrong. Just seat the shims properly and adjust the lash in spec and you'll be good to go. PS, sorry to read about your motor bummer[img]i/expressions/face-icon-small-sad.gif[/img]
Old May 28, 2003 | 10:38 AM
SANDMAN430's Avatar
i don't have shim under bucket and mine gets reved a lot. i think i read dsmike doesn't run shim under bucket, and i think i saw he runs hugh cams. plus the shims are easy to find and not hard to adjust.
Jason Poulin
Sep 20, 2015 02:49 AM
Jul 15, 2015 02:07 AM
FrozenFeline
Mar 27, 2005 12:47 PM
Maxpower
Mar 7, 2004 12:48 AM
Hightower
Jul 29, 2002 04:59 PM
