Talk about problems with new DS650's
Old May 12, 2000 | 11:44 PM
  #31
ScoobyDFW's Avatar
How'd it go with the Bombardier reps?
By the way, the neutral light is unreliable. Half the time the light does not come on when it is in neutral, so I don't pay much attention to it. However, if the light does come on, it is for sure in neutral. I had the neutral sensor replaced and it didn't make any difference.
Old May 13, 2000 | 03:14 AM
  #32
desertds's Avatar
I have had only jetting problems with my DS and other than that it has performed flawlessly for two months. I finally got the big gun pipe and got it on tonight so maybe tommorrow I can let ya know the outcome on performance gains. This quad is all speed and handling, anyone who says otherwise is a novice rider that doesn't know how to ride or simply has not rode a DS period. this quad rocks
Old May 13, 2000 | 08:56 PM
  #33
1BadWarrior's Avatar
You know some of guys take a little to serious I am just messing with about stuff and then you guys go off and start saying crap just because your mad. Well I choose Yamaha and they make me happy. So I am leaving cause around this forum you just can't joke with people.
Old May 14, 2000 | 03:07 PM
  #34
Bomber's Avatar
I guess there was a hold up in canada they are supposed to be comming tuesday the 16th. I'll let you know what happens.
Bomber
Old May 15, 2000 | 10:22 AM
  #35
DSaholic's Avatar
Well I finally ran into my first problem. The Axle seams to have come loose. If the bike is off the ground you can move the axle back and forth about an inch. I think that the axle nuts have come loose. I don't think that the bearings got damaged but I will take it to the dealer this week so they can look at it.
Old May 15, 2000 | 11:24 AM
  #36
CRTLeech's Avatar
The axle retainer has a nut and bolt through it that comes lose. You need to tighten the retainer by turning it COUNTER-clockwise and then tightening the nut on the bolt.
I had the same thing happen and discovered it soon after it had happened. I don't think that anything happened to the bearings, but I won't know without tearing it apart. It tightened up nicely, once I figured out that it went backwards, and everything seems fine. There's no slop, no squeeks and it rolls just fine.
Luckily, the only thing this cost me was a day of riding and 6 hours of driving, round trip.
Good luck,
CRT_Leech
Old May 15, 2000 | 12:57 PM
  #37
DSaholic's Avatar
Hey thanks I'll try that tonight. Maybe I'll even ride!!! Wasn't planing on that! Later and thanks again!
Old May 15, 2000 | 01:30 PM
  #38
DSaholic's Avatar
Have any of you guys had problems with your brakes squeaking? Mine squeak quite a bit. They seam to work fine but the squeaking is starting to **** me off. Only the front brakes squeak the back is fine. I tried cleaning them with break cleaner and that helped for a while but they start squeaking again after about 2 hrs. Any ideas?
Old May 15, 2000 | 03:31 PM
  #39
m20galaz's Avatar
you should have waited for the new yamaha high performance 660 quad 6-10-2000
Old May 15, 2000 | 03:49 PM
  #40
juventus's Avatar
It really, really pains me to hear all of these horror stories from fellow ATV riders who have paid so much money for a crappy 1st production-run machine. I'm practically feeling sick to my stomach....must....go...sit....down.....and count my blessings!
