sprockets
Old May 21, 2000 | 08:38 PM
ScoobyDFW's Avatar
No, not the axle lock, the right rear hub nut that keeps the hub on the axle. The sprocket won't come off unless I remove the hub.
Old May 22, 2000 | 11:23 AM
CRTLeech's Avatar
Try an impact wrench. If you don't have an air compressor and impact wrench, ask around for an automotive shop if they will zip it off for ya real quick. They shouldn't charge much, if anything.
If you can afford it, I would highly recomend an impact wrench and at least a 5.5HP air compressor with a 20 gallon tank.
Good luck,
CRT_Leech
buddieboy
Dec 9, 2016 05:50 PM
merryman
Sep 19, 2015 03:15 AM
Canamaniac!
Sep 15, 2015 06:19 PM
Old Deer Hunter
Sep 2, 2015 01:39 AM
Dammar
Aug 26, 2015 07:12 PM
