Ride review of my rebuilt DS.
Old Jul 14, 2003 | 02:12 AM
ironrod's Avatar
Default Ride review of my rebuilt DS.
If the pump is set up right, the TM45 will not bog off the line, the pump was made to correct that. I'm glad you got good power! [img]i/expressions/face-icon-small-happy.gif[/img]
Old Jul 14, 2003 | 02:36 AM
Gashog's Avatar
MudStud, thanks for the review and the information. I'm interested in your setup. Where did you get your carb from? Did you do the work yourself? Did you have any problems matching the carb to the intake manifold boot or the air filter boot? Have you heard if the Lectron would be too large for a stock engine, with a good intake and exhaust?
Old Jul 14, 2003 | 02:46 AM
MudStud's Avatar
Gas Hog,
Email me at gradyvogt@hotmail.com for any questions on where I got it. I hang by the no public advertising rule here so I don't get stuff deleted...
No, the carb and Intake were matched together by my mechanic, same person I got the carb setup from.
Yes, I did the work I could on my own. I had my valve springs installed as I did not have the tool. I had my porting done by a mechanic..
It fits PERFECT into the airboot. The opening of carb is the same size as the stock carb. ITs walls are not as thick.
My engine BORE is stock, i raised the compression and added different cams. I dont see why it would NOT work with a stock setup.. THey DO offer a 44 HV.. meaning its starts as a 46 then tapers to a 44. That might be a good choice.. The also make a regular 44mm bore and it is much cheaper..
My Carb/Intake Porting/Twist/Cable came to $675. But so far it has been worth it!!!! The mechanic sets up the carb 95% of the way. I have NOT touched any jetting on it yet. .Not sure if I ever will..
Old Jul 14, 2003 | 02:52 AM
ThePunisher's Avatar
I beleive that the Lectron carb would be the better route to go. It is very similar to my friends Big Air carb design and they do act like fuel injection. And they are realitvley easier to dial in than a TM. I don't think 9700 R.p.m.'s is a bad thing! Those valve springs are actually rated at 10,200 R.P.M. Have fun and enjoy those mods, makes me wish I wasn't selling my quad.[img]i/expressions/face-icon-small-sad.gif[/img]
Old Jul 14, 2003 | 10:46 AM
  #15
SANDMAN430's Avatar
the stock engine will turn that highwith cdi in nuetral, but with out the springs your piston will start to smile until a valve bends.
Old Jul 14, 2003 | 11:49 AM
  #16
buttfungus's Avatar
The truth is out there![img]i/expressions/face-icon-small-wink.gif[/img]
Old Jul 14, 2003 | 09:59 PM
  #17
TyreSpinner's Avatar
Why are you selling the quad you put your sweat, blood and many hours in it?
honda71
Jul 12, 2015 05:56 AM
Robbbb55
Jul 8, 2015 02:11 PM
honda71
Jul 8, 2015 02:13 AM
Coryco
Jul 6, 2015 07:30 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
