still looking for tm45mm carb info!!!
Old Jul 13, 2003 | 11:20 PM
DStroyer's Avatar
Default still looking for tm45mm carb info!!!
Old Jul 13, 2003 | 11:21 PM
DStroyer's Avatar
Also, I fired up the quad, and within 1 minute, the head pipe is glowing read, factory jetting with carb.
Old Jul 14, 2003 | 01:41 AM
ANNIHILATER's Avatar
No Mercy Racing! Got NOS?
Depending on your elevation, the TM45 usually comes with a 45 main jet, and i personally run my air fuel mixture out 1 1/2 turns out. what is your elevation??? mine did that a few times but were i was riding in high elevation and the air density was very thin and it was cold out, and head pipes were glowing, i had no probs though...
Old Jul 14, 2003 | 01:53 AM
TyreSpinner's Avatar
45 main jet?!?!?
Not sure if you meant pilot jet. But the default main jet on the TM45 is 150 I think.
Old Jul 14, 2003 | 02:09 AM
MY TM 45 came with 145 main jet straight from ron woods, I SAID 45 I MEANT 145!!!!!!
Old Jul 14, 2003 | 02:16 AM
Sorry I'm dumb.
Mine came with a 150 from RWR.
Oh well.
Old Jul 14, 2003 | 02:28 AM
its all good, i like the roosten on your childrens, childrens....
I be layin down a roostin on you and your neighbors childrens, childrens, grandchildrens, friends, cousins, brothers, sisters,half sisters friends embryo!!!!!.,,,,,,,,,,,,,,LOL and throwin a roost 70 feet back with 12 paddles.
Old Jul 14, 2003 | 11:11 AM
SANDMAN430's Avatar
have you done a plug check? i also run the 145 main so you should be to lean if you are in that area. the stock pipe will glow at night or in the garage.
Old Jul 14, 2003 | 11:18 AM
DStroyer's Avatar
Hey,
I got it all figured out. The air screw was way out and the idel screw was way in. Thus making it way to lean. I broke in the cams at 2000 rpm without any glowing at all after I adjusted everything. Its to bad my head pipe turned blue so fast though. Anyway, I appreciate everyones input.
DStroyer
Old Jul 14, 2003 | 11:25 AM
lmao...
GregM
Mar 6, 2018 06:53 AM
ltrmc02
Jul 22, 2015 04:50 AM
ghost3
Jul 19, 2015 08:46 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
