Changing front sprocket.
Old Aug 2, 2003 | 06:30 PM
PureIntimidation's Avatar
Default Changing front sprocket.
Any tips or hints? Step by step. I take it I will have to adjust the chain as well right?
Changing stock to 15t
thanx
kenny
Old Aug 2, 2003 | 06:33 PM
TyreSpinner's Avatar
I was also wondering...Never done it before.
Old Aug 2, 2003 | 07:52 PM
MudStud's Avatar
Steps..
1: loosen the 2 rear bold/nuts that close the axle careyer.
2: Removed the 3x 5mm bolts that cover the front srocket.
3: Using a 30mm remove the sprocket bolt. You may want to use an airgun to remove it. It also helps if its in first gear
4: Using a slender shaft or scredriver place it throught the holes in the REAR sprocket hub and incert it into the axle housing.
5: Put the quad in Neutural.
6: Rolling the quad backward will loosen then chain and will allow the front sprocket to SLIDE off with the chain on.
Make sure you pay attention to what side of the sprocket comes off first!!
7: There is a crush washer, some people replace this, I just flatten it out and reuse it. Never had an issue.
8: put the sprocket IN the chain loop and then slide it onto the main shaft.
9: Put the crush washer in and lock that nut down.
10. Tighen the chain to rider weight specs. I use 3/4 slack.
11: tighten the rear housing bolt/nuts down
12: replace your sprocket cover and nuts.
The ENTIRE process takes about 10 minutes.
Old Aug 2, 2003 | 07:59 PM
MudStud's Avatar
Torque Specs
REAR BOLTS on the housing 21 ft lbs
Sprocket nut is 103lbs
Front 3 bolts are NOT listed on the manual for torque so I would just get them SNUG. I would recomend 89 in lbs or 7.5 ft lbs.
rcappie4
Jul 18, 2015 07:51 AM
JackTheKing
Jul 14, 2015 09:09 PM
tporath
Jul 11, 2015 12:31 PM
jettman
Jul 6, 2015 12:16 PM
Mphillips
Jul 2, 2015 07:20 PM
