polishing tricks
Old Sep 7, 2003 | 01:07 PM
SANDMAN430's Avatar
Default polishing tricks
while at ds days the subject of polishing came up, well i use a high speed drill and a polishing bar they come in brown green and white, brown being the most cut and white being the least, i can get thru the green stage and get tired and call it good enough. well just wondering what, every one else does?
Old Sep 7, 2003 | 03:30 PM
SANDMAN430's Avatar
i've used a grinder also but getting some of the stuff is hard while on the quad. the drill with 2500 rpm works pretty good.
Old Sep 7, 2003 | 04:49 PM
DaSandBomb's Avatar
use mothers polish (by hand[img]i/expressions/face-icon-small-blush.gif[/img])
kc
Old Sep 7, 2003 | 08:21 PM
DSJOBBER's Avatar
Yes you will need a drill that will turn at least 2500 rpm if you are using a 8" polishing wheel. Check out Jestco Polishing.com or English Custom Polishing. Both sites have step by step instructions as well as the proper tools to use etc. Polishing is like a art form either you have it or you dont.
Old Sep 7, 2003 | 10:09 PM
DCryder's Avatar
Polishing is over 50% of my job. I maintain and repair molds at a automotive injection molding factory.
SEMICHROME polish on a KLEENEX is the best polish I've ever seen for a final shine!!!
Old Sep 8, 2003 | 01:32 AM
mystereid's Avatar
It's official, I've been duning for over 30 years.
I use hollywood polish carried by G.I Joes for light polishing. It comes in a cotton wadding like neverdull only better plus you can get different grades. Harbor Freight carries a cheap dual wheel polisher like a grinder only the wheels extend out for polishing inside weels.
Old Sep 8, 2003 | 04:59 PM
Bajaboy650's Avatar
The best bet is to use an actual bench polisher. I have an 8 inch and it works great. Also the more hp the better because most grinders tend to bog. You have the keep the heat up to get a good shine with minimal effort, but watch it because you can burn the metal. Also a Sisal wheel ( which is like a wheel made from rope) and a Black emory compound is the best combo for fast cutting. Then I switch to a tight sewn wheel and the Black compound , Then I use a Medium sewn wheel with a Brown compound , then I finish up with with a loose wheel and green compound. Keep in mind these are the steps i take to polish aluminum. There are different ways to polish different metals. Hope this helps. Oh and by the way my dad used to own a polishing and chroming shop. [img]i/expressions/face-icon-small-smile.gif[/img]
snake99
Sep 30, 2015 07:31 PM
Brandon400
Sep 5, 2015 08:44 PM
mattcraig1
12
Aug 27, 2015 12:23 PM
Captjay
Jul 23, 2015 12:33 PM
