DS650 Riders...I need help fast!!!!
Old Oct 3, 2003 | 06:14 PM
LEP7MM's Avatar
Default DS650 Riders...I need help fast!!!!
riding tomorrow with MudStud and today I noticed that one of the hoses in the front of the case is wet and covered in oil. I barely moved it and it came apart.
I'm guessing it's only a vent, but the hose coming out of the case is only about 2" long and goes into a larger hose which runs up to the intakes for the airbox. This doesn't seem right. Should it come apart that easy? I put a zip tie on it to hold it for now, but plan on putting a longer hose on after the ride.
Is this something that I should be concerned about? The hose looks like it has been cut and put back together.
Old Oct 3, 2003 | 06:23 PM
SANDMAN430's Avatar
you can get some copper tubing to fit inside and hose clamp to make a quick repair so you can make your ride.
Old Oct 3, 2003 | 06:29 PM
LEP7MM's Avatar
one hose is stuck into the other. Each hose has a different i.d.
Old Oct 3, 2003 | 06:38 PM
SANDMAN430's Avatar
some guys have switched it to the blue see thru tubing.
Old Oct 3, 2003 | 07:20 PM
Eaglecollector's Avatar
That is the way the come from the factory. Except not covered in oil. I have a hose clamp on mine just to keep it snug and then silicone at the joint as well. That keeps it so you don't get any oil mess.
Old Oct 4, 2003 | 12:04 AM
lilnotts's Avatar
mine melted on the pipe so i used some braided line, looks pretty cool, but i did hafta leave about an 1 1/2" of it for the airbox hose so that way it'd b still tight
Old Oct 4, 2003 | 12:10 AM
SANDMAN430's Avatar
re route that tube mine melted also
Old Oct 4, 2003 | 04:22 PM
Yep...also used stainless steel braided line. And I routed it up alongside the radiator frame so now it terminates under the hood with a filter on it. Looks like a K&N but it's not. Got it from Auto Zone I think. And the braided line from Pep Boys.
Old Oct 7, 2003 | 08:29 PM
subnuke3363's Avatar
the unknown tube is your crank case vent. I initially rigged something similar to Eaglecollector, but it started dripping oil all over the place. Bought some HP air hose like the air hose at the gas station, ran it straight from the case up the frame by the radiator, under the gastank, down and connected it to the plastic guard over the front sprocket. Used a hose fitting to screw it into the hole i drilled into the plastic. now if the crankcase vents, the oil goes on my chain (subsequently lubing it). Brother has a 4stroke KTM dirtbike that the local shop did that to his.
Pehter
Oct 3, 2024 11:00 PM
ReconBayou
Oct 31, 2022 05:37 PM
Irishman301
Sep 23, 2015 01:47 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
01ssls1
Sep 22, 2015 06:50 AM
