DS hard to start?
Old Oct 20, 2003 | 01:01 PM
dsguru's Avatar
Default DS hard to start?
Lately my 2001 ds has been very hard to start when cold ,if it starts at all.If I spray gas down the carb it will start but only full throttle and cranking forever.It starts fine when warm.I have had the carb apart a few times now and I don't see anything wrong,cleaned out every jet and passage.Has anyone had or seen this problem?I don't know what else to do except try another carb.
Thanks in advance.
Old Oct 20, 2003 | 01:09 PM
sam's Avatar
sam
did you try plugs yet?
Old Oct 20, 2003 | 01:14 PM
dsguru's Avatar
Yes I tried plugs didn't help.
Old Oct 20, 2003 | 01:22 PM
DuneMe's Avatar
Check your valve clearances!
Do a search on this topic.
This should fix your problem.
Old Oct 20, 2003 | 01:25 PM
Eaglecollector's Avatar
How long has it been since you last checked the valve clearences? I know that when they are out of specs it's real hard to start. Worth a look.
LOL...I type to slow[img]i/expressions/face-icon-small-blush.gif[/img]
Old Oct 20, 2003 | 01:30 PM
ScoobyDFW's Avatar
are you using the choke?
Old Oct 20, 2003 | 01:58 PM
dsdrew's Avatar
When my 02' Baja is cold i will take the snorkels from the top of the air box and hold the ends together in my hands. That way no air is hardly getting in.
Otherwise it just cranks and cranks and maybe start. Where im at it is usally high of 50 degrees.
Old Oct 21, 2003 | 01:08 AM
Entomber's Avatar
My Raptor had similar starting problems. I had the valves adjusted.. starts on the dime now. My DS had a similar problem... and I never really had the valves checked.
MikeyBoyesq
Nov 27, 2020 02:44 PM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
Ty Speece
Jul 2, 2015 04:59 PM
1000gade
May 27, 2015 12:37 PM
dunc_n
Aug 26, 1999 09:32 PM
