Lectron 46HV Carb???
Old Oct 27, 2003 | 05:44 PM
dsracer666's Avatar
Default Lectron 46HV Carb???
where do you guy buy your carbs?
Old Oct 27, 2003 | 06:16 PM
MudStud's Avatar
Check your PM
Old Oct 27, 2003 | 08:18 PM
crazypainter's Avatar
I see a lot of you are using the Lectron on a stock motor is there a big difference over stock?
Old Oct 27, 2003 | 08:45 PM
CountryJoeGlass's Avatar
YES![img]i/expressions/face-icon-small-happy.gif[/img] From bottom to top end & seems to rev quicker IMO![img]i/expressions/face-icon-small-smile.gif[/img]
Old Oct 27, 2003 | 08:53 PM
  #15
atvaddict01's Avatar
has anyone used it on the 04 and how ward is it to put on also do you have to change the endcap
noise is an issue by my house dont want to ruin my fun[img]i/expressions/face-icon-small-smile.gif[/img]
Old Oct 28, 2003 | 09:30 AM
  #16
MrHorsepower's Avatar
Pro Rider - Oldham Racing
BUILDS THE FASTEST DS's ON THE PLANET!
Want a hot DS, or maybe one of the fastest DS's on the planet? This is the man to contact!
Blackhawk save your money on the cdi. The stock DS makes peak power at 6200rpm. By time you reach the 7900rpm rev limiter its time to shift. Just my opinion.
MrHorsepower
Old Oct 28, 2003 | 11:03 AM
  #17
ironrod's Avatar
MrHorsepower
Eric,
Well, in my opinion, most aftermarket CDIs also enhance power, not mearly raise the Rev Limit. Therefore, If you increase the power curve (by use of an aftermarket CDI, and other performance parts) good power will be generated up to as high as 8500 RPM. Raising the limit would then be needed. So, if you are planning more engine mods, it makes sence to get an aftermarket CDI that can take advantage of that new-found power at higher RPMs. That being said, I've never seen a gasoline running DS650 case (at least not yet) where a Rev limit above 8500 RPM made sence; Like you say, at that point, its time to shift!
Marky
Old Oct 28, 2003 | 01:17 PM
  #18
BillDS650's Avatar
If the Lectron is not make HP after 6200 RPM it is not a good carb. I know that 40mm Edelbrock with stock CDI and Alba pipe,K&N with open air box had not hit its peak HP # when it hit the rev limter. The Ron Wood CDI HP peak out aroud 8400 too 8600 RPM.
Old Oct 28, 2003 | 08:27 PM
  #19
dsracer666's Avatar
bill were did you get the edelbrock carb and air box?
Old Oct 28, 2003 | 08:43 PM
  #20
TyreSpinner's Avatar
He has a prototype... The only one (or one of few) made.
