DS650 clutch lever?
Originally posted by: Gaskett
I put an e-z pull clutch handle onmine.. Made all the difference in the world.
I only use 2 fingers to pull the clutch, the rest is gripping onto the bars for dear life.
#17
#18
#19
I just got the number off of maguras website and called them.
The guy was very helpful and sent out the kit right away.
Installation was a snap.
Be careful that you put some red locktite on the cap that screws on to the end of the cable.
Mine unscrewed itself out in the middle of BFE.
Also if you can afford it, get the stranded cable.
#20
Gaskett,
Have you had any problems with it? I e-mailed Magura and they said they were making a DS650 specific kit. I forget what they had to add on to it. I agree. DS has a heavy clutch lever pull and adding a mandatory stiffer springs will only worsen it. Yeah you can get used to it, but why should we? If there is an option to soften it up by all means do so.
