stage 2 or tvi 720
#31
stage 2 or tvi 720
I talked to Gary about my question before his kit came out.. And he only told me all the power I would lose and that an he COULD do it if I really really wanted. I explained I run 90-93 gas and I just can go higher on compression. He told me to carey fuel additives.. I did not really like it.. He really avoided my questions also. Otherwise I would have done the 720 over my stage II. It was the compression question he would not answer...
#32
#33
stage 2 or tvi 720
Thanks Big Daddy331.
Fuel additives are total junk. When they say they raise your octane by 5 points it means this.
93octane + additive = 93.5
All he has to do is face a small amount off the top of the piston to reduce total positive dome cc's to an acceptable compression ratio for pump gas. Or offer a completely different lower compression ratio piston.
MrHorsepower
MrHorsepower
#34
#35
#36
#37
stage 2 or tvi 720
Another vote for the 720. I had a stage II before going to the 720 & it really confirmed the old addage of no replacement for displacement. Simply more power everywhere! I have been using 100 octane Sunoco GT 100 with no problems at all, also only $3.69 per gal. here in West, by God, Virginia! I highly recomend the 720 over stock bore setups although you can get a good running stage III close to a 720 on flat ground. I prefer the torque of the 720 to match my riding style, with stock valves (for now) Web 110 cams & TM 45 with pump activated & tuned properly you can't imagine how much grunt this thing has. Oh yeah, she'll run pretty damn strong on top too!
#38
stage 2 or tvi 720
With all this talk about race gas and compression, I was wondering how Yamaha can sell at least three of their newest bikes off the show room floor running 11.9 and 12.4 to 1 compression. The YFZ is 11.9 and the R-1/6 is 12.4
Can they get away with this by detuning the ignition module or are they magic? It almost appears we could go to our stock ignition curve and run 91-93 octane pretty safely with a 12.5 to 1 ratio.
jbt
jbt
Elkaholic
09-06-2015 02:44 PM
