carb spring
Old Nov 9, 2003 | 07:23 PM
arnold's Avatar
Default carb spring
what should be the exact mm of the carb spring i cut three coils of and drilled to holes 1/8
But is there a exact mesur for the spring thanx???
Old Nov 9, 2003 | 08:47 PM
SANDMAN430's Avatar
Default carb spring
might want to call mr hp on cutting that i've seen guys do that and i didn't see any difference.
Old Nov 9, 2003 | 11:23 PM
Oldmanracing's Avatar
Default carb spring
The factory seems to have used two different spring lengths.
Be carefull and do not go shorter than 3 inches.
Total active length is 2 7/8. If you go shorter than this your slide will be bouncing and running very rich at slow speed.
I agree that performance varies. Best performance seems to be only when you run a direct carb-mount filter or lid-on uses. Running lid-off appears minimul.
I am getting ready to test 3 proto springs that I hope to match direct,lid or lidless.
Weather has prevented me from testing.
Old Nov 10, 2003 | 12:09 AM
busmechanic's Avatar
Default carb spring
I do not know what the dyno results would be, but I drag raced several times with the lid on and off. I could not tell a difference. I did notice at a idle I have better throttle responce when snaping the throttle with the lid on. lid off, it seems to choke a little before catching up. sometimes it even died. I think I will leave the lid on unless somebody has dyno results to prove otherwise.
Old Nov 10, 2003 | 10:37 AM
SANDMAN430's Avatar
Default carb spring
i think there is some dyno results out that show leaving it on is better, now if i could find that little black plug, and the drain cover[img]i/expressions/face-icon-small-smile.gif[/img]
Old Nov 10, 2003 | 11:12 AM
Default carb spring
Direct mount will generate the most peak horsepower.
However, running with the lid generates the most torque and widest horsepower band.
That is why I am testing new springs to have the best of both torque and hp.
ghost civic
Jan 15, 2020 07:43 AM
GregM
Mar 6, 2018 06:53 AM
Wnthunting
Jul 9, 2015 03:02 PM
Jkfx400P
Jul 6, 2015 10:04 AM
Mphillips
Jul 2, 2015 07:20 PM
