Procomengineering CDI...Any good?
#23
Originally posted by: JEFFROE
same $$$ as duncan $399.00 mark how much messing with different settings did you do after installing kit befor you you'r were happy with the two different modes?
#25
Jeff,
I moded other items at the same time. There is no way I could tell you it was a gain over any other CDI itself. A dyno would be the best to tell - Its a lot like an exhaust.
Marky
Marky
#27
Originally posted by: ironrod
Here's the latest: Procom may make CDIs for Alba and Big Gun, but after the lawyers got out the big sticks, it appears that Procom is in fact using thier own curve, not the Big Gun power curve as they have been advertising. Its important to note that Big Gun promises to improve horsepower, and will now be publishing its power curves and comparative horsepower gains over stock. The word is that Procom will refuse to publish its dyno. Interesting. What about Alba? Well thier boxes are exactly like Procom, with the same curve as Procom.
Its pure conjecture on your part that the Procom was ever the same as Big Gun.Sounds to me like Big Gun never had a case ( I wouldn't be surprised if this whole deal wasn't a fabrication!).
Trying to say the timing curve is intellectual property would be damn hard to prove anyway, A change of 1 degree or .5 of a degree anywhere in the curve would negate any claim that it was a copy.
If RWR or Eldebrock or TVI or Trinity sold you a jet kit or complete carb and you "reverse engineered it" and posted in a thread here the exact jetting specs, would you also be liable in the same way you claim Procomm was?
Procom refusing to publish dyno results? Wasn't it you that said they had no test quads?
#28
mark did vortex set up the rev limit on you'r box? it said that a tech has to do this?
The curves can be re-programmed, but mine was set up by vortex - simply out of the box - no re-programming.
Marky
#29
Originally posted by: truckracer
I call BuIIshlt...............
Marky
