'04 headlight install, pictures
Old Dec 27, 2003 | 09:34 PM
BajaIowa's Avatar
Default '04 headlight install, pictures
My dealer. I get a 10% disc. and free shipping. Even at full cost plus shipping, it should be way cheaper than $115. As far as adjustment goes, you could weld a nut on the frame and then use just a screw attached to the light and just screw it back and forth. Just a thought.
Justin
Old Jan 12, 2004 | 03:05 AM
DuneMe's Avatar
Finally decided to do the install today. I have a bunch of pictures of everything I did. There are some gromets that should be ordered with the lights and bracket to get everything to install easy. I also used male wire connectors to make the connection between the old style light connector and the new style one. When I get back from 4SW's I'll try to post the pictures.
Does anyone have a web site to post instructions / pictures these days? I know Buttfungus had some of these but, I think someone else was going to take over his info.
Old Mar 4, 2004 | 01:14 PM
Dragorus's Avatar
Originally posted by: BajaIowa
Hey, just put in a new style headlight in my '03 Baja. You can look at my pics page and see some closeups of the install. It was very easy. All the thanks has to go to ds650uk for getting the part #'s on a previous thread. The install goes as follows.
Remove old headlight keeping all hardware and rubber grommets.
Install the two new brackets on the new headlight
connect wiring- I just used short pieces of wire with male spade terminals on both ends and siliconed them into the plugs
Install headlight on quad. It uses the same bolts that the old headlight uses
There is a plastic cover that needs to be installed on the nose plastic
There are two small holes that need to be drilled into the plastic. The location can be seen on the bottom of the plastic. Just hold the trim piece up to the nose plastic and then flip it over and you will see where the holes are supposed to be.
Put the nose plastic on
It really was easy. Have a look and tell me what you think.
Part #'s
Headlight 705000805
Trim cover black 705000806
Trim cover yellow 705000986
Trim cover orange 705000871
Mounting bracket 705000904
Mounting bracket 705000905
Justin
p.s. I won't be back until sunday night, so I won't be able to answer any questions till then.
you had to cut the original headlight plug?....if so did you just double the connections??
Old Mar 4, 2004 | 01:27 PM
Dragorus's Avatar
Originally posted by: BartlettRacing
I would like one of the old style head light setups ....... any of you guy's keep it ? pm me and let me know .... Im interested in some testing ......
As soon as I get mine I will have the old one avail..
Old Mar 4, 2004 | 08:12 PM
  #15
BajaIowa's Avatar
Draforus, no I did not cut the plug. I just just spade terminals at both ends of short pieces of wire and connected the old plug and new headlight.
Justin
Old Apr 5, 2004 | 07:02 PM
  #16
rykid's Avatar
i just ordered my 04 headlight and so far the prices are....headlight with bulbs is 56.47$ orange trim piece is 5$ one bracket was 5.76$ and the other was 7.96 grand total was 75.19 not to bad cuz the 02 headlight was 110 and the new one is only 75 guess its a good deal [img]i/expressions/face-icon-small-smile.gif[/img] justin youve helped me out a lot man thanks ill be intouch when im ready to install it ryan
Old Apr 5, 2004 | 07:11 PM
  #17
1BigDSRider's Avatar
Who did you order yours through.
Old Apr 5, 2004 | 08:20 PM
  #18
Dragorus's Avatar
Yea we all wanna know...Thats extremely cheap yo!??
Old Apr 5, 2004 | 08:48 PM
  #19
BajaIowa's Avatar
I think he got his through his local dealer like I did. It was only $66 for me from my local dealer. If you guys only knew the mark up on this stuff. If you bought your quad from a dealer make them give you a good deal on parts. Mine is 10-20% off and shipped to my door for free.
Justin
Old Apr 5, 2004 | 11:51 PM
  #20
rykid's Avatar
i got mine through a place called bobs ski doo in mass its just a regular bomb dealer i gave them the part #;s and thats the price they gave me if anyone needs the phone # its 1508-238-3200 maybe they can ship it to you for cheep pm me for anyother questions
