Engine Cutting Out
Old Dec 26, 2003 | 12:44 AM
dadbandit's Avatar
Default Engine Cutting Out
Engine Cutting Out
Just got my engine back together a couple of weeks ago, New Web cam and valve spring, New 11.5/1 piston (stock bore), ported and polished, dual Mikuni’s, RWR CDI, Power Pro pipe. After the initial break-in ride it was running great. Went out for the second ride and was doing a jetting run when it cut out bad at 6000-7000 RPM. Pulled over and oil was coming out the breather. Took out the check valve and cleaned it and reinstalled it to specs, changed the filter and oil. Still a little blow by but it has always been that way. Did a leak down test (6%) and checked the valve clearance all good. Took it out again still cutting out, changed the CDI still cutting out. Put back on the single Carb still cutting out. Anyone have any ideas or suggestion or similar experience. Need Help.
Dadbandit
Old Dec 26, 2003 | 01:02 AM
ironrod's Avatar
Thats a lot of carb for the stock bore and stock valves. I don't know how to tune the duals, but maybe somone can ring in and give you some jetting advice on the duals for a stock valved and stock bore.
Old Dec 26, 2003 | 01:07 AM
ScoobyDFW's Avatar
fuel starvation? fuel petcock filter dirty?
loose coil wire - must be very tight, not loose.
Old Dec 26, 2003 | 01:16 AM
dadbandit's Avatar
Hey Scooby
How you been. I remember when you had your coil problems a couple years ago. What was the symptoms/cause/solution.
I will pull the petcock and check.
Ironrod
As far as the jetting I have run these dual mikunis for awhile without any problems.
Dadbandit
Old Dec 26, 2003 | 02:32 AM
ironrod's Avatar
Ok, I thought you said they were new. If the jetting worked before it should work again. Like scooby said, check the fuel petcock and I might also add to check your vent breather hose for the gas tank. Sometimes those clog. Check it by loosening the gas cap when it cuts out. If loosening it cures the problem, then you'll need to get the pinch or clog in the line taken care of.
Marky
Old Dec 26, 2003 | 01:51 PM
Endomaniac's Avatar
Old Dec 26, 2003 | 01:54 PM
Endomaniac's Avatar
Not enough air getting to the gas tank would cause this... I pinched my vent tube once and thats what it would do it would run great for a bit then it would act like it was running out of fuel then die.... check your vent see if it starts right back up when you take the gas cap off.
Old Dec 28, 2003 | 01:05 AM
dadbandit's Avatar
Well spent the morning removing and flushing fuel tank, rerouting the vent tube, chanbging fuel line, unpluging and cleaning all electrical plugs and coil connections. Took it out and now it hits 9000 RPM without any problems.
Old Dec 28, 2003 | 10:11 PM
Endomaniac's Avatar
SWEET!
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ltrmc02
Jul 22, 2015 04:50 AM
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
clsharky
Jul 13, 2015 02:07 PM
