Darting at speed!!!
Old Jun 29, 2000 | 01:37 PM
ScoobyDFW's Avatar
I have experienced this darting when riding at speed along a sandy beach with some mild whoops - widely spaced and not too tall or steep. All of the sudden one of the front tires will dig in and the DS will want to shoot off in that direction. It is scary to say the least! I was almost thrown off the DS in the opposite direction that the DS wanted to dart to. The large front end weight bias must be contributing to this problem.
Old Jun 29, 2000 | 01:46 PM
atvinstructor's Avatar
Bingo!
Old Jun 29, 2000 | 04:32 PM
Thor's Avatar
Make sure that your toe-out is at factory specs.
Old Jun 29, 2000 | 04:58 PM
ScoobyDFW's Avatar
Thor, The spec says total toe-out = 2.6mm +- 0.5mm. What is this? How do I measure it?
Old Jun 29, 2000 | 08:43 PM
Ang's Avatar
Ang
Scooby- toe out is set by measuring the distance between the front tires on a horizontal plane front and rear toe out means the front is wider and toe in means the rear of the tires are wider.
it also best to measure this under load with near your wieght at riding position. An easy way to determine toe is to take 2 straight edges that stick out front and rear of the wheel use 2 tape measures one front and one back.
I hope this helps it's easy to do but hard to explain. good luck
Old Jun 29, 2000 | 11:41 PM
BlackHawk's Avatar
I think i actually understood that explaination of how to meaure the toe. I commend you on your efforts to explain that one.. :P
Old Jun 29, 2000 | 11:58 PM
Ang's Avatar
Ang
Scooby- I sent you an E-mail with a crude drawing then I mentioned bump steer, although it is important I don't think you will have a problem I really did'nt mean to confuse matters with a bunch of possibilities, sorry.
Old Jun 30, 2000 | 12:26 PM
87_250R's Avatar
Ang is right. You the man
Pehter
Oct 3, 2024 11:00 PM
ReconBayou
Sep 23, 2015 02:41 PM
mywifesquad
8
Sep 21, 2015 08:20 AM
Ridgerunner665
Sep 15, 2015 01:20 AM
