Want to Rebuild my Rear shock
anyone know where to get these things rebuilt and the cost? Anyone know of place in AZ? Just got the triple rates up front and now need the rear done.
Second question: How do you adjust the Toe and camber settings when you install the ASR upper a arms? I got them on and don't know if I should play with the tie rods or not
I don't know about any place in AZ to rebuild your shock, if I were you though I would have TCS do the work. They probably have the most time spent working on DS shocks and I have raced on their stuff and it works great. Turnaround is useually less than 3 weeks (that is light speed in the shock biz) and will probably run you less than $300.
As for the ASR settings, look around in the Bomb forums and find Ironrod. He should be able to kelp you.
