Help!! Newbie DS owner.
Old Feb 16, 2004 | 03:20 PM
Yardbird's Avatar
Default Help!! Newbie DS owner.
I've just finished breaking in my new Baja 04 and want to change the engine oil. I removed the dipstick, took out the drain plug and the removed the oil filter. There was some oil that drained out ot the crankcase and from the oil filter. But the thing holds like 3+ quarts of oil and no way did that much drain into my oil pan. There is still oil in the external tank because I can still measure it with the dipstick. My question is about the bleed screw behind the oil filter. The owners manuals shows a pic of it and points to it in the picture, but I couldn't find anywhere in the oil changing procedure what this does. Does this bleed screw come out and is it for draning the external oil tank? I tried taking it out with a fairly big flat head screwdriver but it doesn't want to budge. I don't wanna go torquing on it without knowing what it does. Any help would be appreciated...........Thanks.
Old Feb 16, 2004 | 03:24 PM
DSJOBBER's Avatar
Dont forget the drain plug at the bottom of the crankcase. There is also a drain plug on the oil tank which im assuming is the one you already took out?
Old Feb 16, 2004 | 03:28 PM
Yardbird's Avatar
I took out the drain plug on the bottom of the engine. There is a drain plug for the external tank also?
Old Feb 16, 2004 | 04:18 PM
Yardbird's Avatar
Alrighty I'll check first thing after work. Thanks for the quick help.
Old Feb 16, 2004 | 09:18 PM
thebigshow's Avatar
i had the same problem with my bleeder screw. i couldnt get it to budge when i was trying to prime the oil.
Old Feb 17, 2004 | 10:45 AM
AZDUNNER's Avatar
After removing the engine drain plug under the bike;
To drain all the oil you need to remove the hose that enters the engine from the oil tank (left side).
You'll spill some oil on the bike but not too much.
I use a funnel to capture most of it.
The bleeder screw behind the oil filter should not need attention on the newer DS models.
The newer, later than 2000 DS's, have a small oil line that comes off the engine supply hose. This line returns to the tank and should bleed any air in the system.
Old Feb 17, 2004 | 11:26 AM
Yardbird's Avatar
That's what I did. After looking at the oil hose routing that looked like the best option. Thanks for everybody's help and now I'm ready to roost Glamis this weekend..........wohoooo!
Old Feb 17, 2004 | 11:34 PM
SandyBear's Avatar
and pull the metal screen out of the bottom of the tank and clean it while you are in there. Especially on your first oil change.
Have fun at Glamis.
Joe454
Nov 20, 2020 01:19 PM
Hack714
Oct 6, 2015 06:51 AM
Hack714
Sep 26, 2015 08:11 AM
kampswas
Sep 23, 2015 05:05 AM
Hack714
Sep 20, 2015 05:54 PM
