DS 03 or 04 how to tell ??
Old 02-25-2004, 01:57 PM
marrtoo's Avatar
Default DS 03 or 04 how to tell ??
Originally posted by: DSSleuth
04's have braided brake lines, shorter alum swing arm, top a-arm is alum, and headlight has 2 bulbs
Originally posted by: jetsnow600
If it has 2 bulbs and is a plastic headlight its an 04, if it has 1 bulb and is a glass headlight its an 03. Pretty easy to tell. Sean
Originally posted by: JMAC650
Also all the 04 models have a alum swingarm and a plastic trim peice around the headlight. The 04 headlight is plastic instead of glass.
Originally posted by: BartlettRacing
look into the head light . if it has one bulb it is not a 04 . if it has two it is .... also the 04's have aluminum upper a-arms if it says baja x on it it is a 04. the x has a lot of exstras on it ......
Originally posted by: TyreSpinner
The baja x is 04 for sure. There is a manufacturing identification sticker with a VIN # and the date it came out of the factory.
But if it's not an 03, the headlight assembly will be different from the 04. The 04 is made of plastic and has an outer trim to it, while the 03's have bulkier assemblies and no outer trim.
hard to explain. But if you can look at both one after the other, you will EASILY tell the difference between the headlights.
Not sure but I think that the headlights might be different[img]i/expressions/face-icon-small-happy.gif[/img] Tyre Sorry I've been away for awhile. Doc's trying to reason with the voices.[img]i/expressions/face-icon-small-wink.gif[/img] Still got a fender though
Old 02-25-2004, 02:32 PM
SANDMAN430's Avatar
i like the frame color way because my 01 has the 2 bulbs and sonn to have the aluminum uppers if the parts ever get pressed in.
Old 02-25-2004, 04:34 PM
lilnotts's Avatar
lol mines a 00 and it has two bulbs
Old 02-26-2004, 01:39 AM
marrtoo's Avatar
Both of mine have the model year on the frame.
  #15
Old 02-26-2004, 03:18 PM
TheSorb's Avatar
I'm not too sure about this, but it seems to me I read somewhere that there's a difference in the headlights...[img]i/expressions/face-icon-small-happy.gif[/img]
