CARB BOWL SREWS STRIPPED, HELP!!!
Everyone strips those out. Vise Grips and then replace them with stainless steel allen bolts when you put them back. Use a little bit of loctite when you reinstall. They used it on the stock ones for a reason[img]i/expressions/face-icon-small-wink.gif[/img]
#15
A pair of needle nose visegrips will work to get them out..... then go to lowes home improvement center, in the hardware isle..... you know the one w/ all the machine screws in the storage boxes.... look for the allen head machine screws on the front of the box. Then open the box and get 4 M40,7mmx10mm allenhead screws and replace your old ones w/ them and you should never have this problem again [img]i/expressions/face-icon-small-smile.gif[/img] That is until you go to move your clip position on the other end of the carb.
[img]i/expressions/face-icon-small-tongue.gif[/img]
