DS POWER TIPS
Old Jul 24, 2000 | 02:59 AM
bdonohue's Avatar
#40 pilot,#155 main. accelerator pump yes. drilled + taped main air bleed and replaced with #40 air bleed jet. i was told i could not do this but i did and it works great. just got sick of trying to jet the carb. the msd is a 6btm box. not the digital. its around $400.00. i had an extra so i tryed it. this is for a 4,6,or8 cyl. engine with a distributor. i'm useing stock coils and mag pick up. i put on a 6" degree wheel and kept grinding a little off the pick up till i came up with 38deg. timing. i think the only reason this system works is the engine fires every 360deg.with two coils. the box thinks its running a 4cyl engine. the only way i could get a tach. to work is to run a 4cyl tach off the box pick up. i would only run this system with a roots type system. not with any blow through set up.i have called msd they were not any help. they told me you can't mix and match like that. i take the stock stuff with me. just in case i'm wrong. have not had time to test very good.
Old Aug 13, 2000 | 11:40 PM
ScoobyDFW's Avatar
bdonohue, What do you think of the various TEAM PAMI stroker kits for the DS650? http://www.team-pami.de/ENGLISCH/PRO...frame_kits.htm.
Old Aug 27, 2000 | 09:26 PM
ScoobyDFW's Avatar
bdonohue, Are you running alcohol with the supercharger? What is involved in setting up a carb for alcohol?
2quiker
Mar 22, 2022 08:36 PM
byronman
Sep 6, 2015 06:34 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Logan Collins
Sep 5, 2015 08:03 PM
toonces
Sep 5, 2015 01:14 PM
