problem!!!!!!!!!!!!!!!!!!!!!!!!!
#15
Well I cant imagine a "Stuck" ring would sounds like that. And thier is no way of knowing what is wrong until you open her up. If you can get the DS for alittle cheaper, with 500 bucks you can replace the piston/rings pretty much everything on the top of the motor. But if its in the lower case of the engine, than your talking $$$$$ depending on wait it is.
What scares me is, if this guy has never clean out his OIL SCREEN in his oil tank, The lack of oil flow could have caused damage to the Crank Bearings,and this what your hearing.
BIgger.
BIgger.
#16
Originally posted by: Btyoe
cmon guys it cant cost that much to bore it and buy a new piston. How much does a new piston cost anyways
