1st dune trip with the DS-help with gearing..?
Old Apr 7, 2004 | 08:22 PM
Hightower's Avatar
Default 1st dune trip with the DS-help with gearing..?
for a stock bike with 22" 8 paddle haulers a 14T for perfect 2nd gear starts is ideal. I actually run 14/41 because I'm a big dude.
I run anything from 14 to 17 and never had to alter the stock chain length.
but if you put on a 14 you gotta turn around the rear engine mount bolt. put the head on the right side, nut on the left, or the little bit of bolt sticking through the nut will get rubed by the chain as suspension travels.
there is no harm, no downside to running a 14T, no seal issues, no issues with the chain turning that hard of an angle, none of that. I got over 300 hours out of my stock chain. countershaft seals wear out eventually regardless of sprocket and they cost $6 when they do - 5 minutes to change. I always have one on hand.
Dingo when you going to SL? I'll be there for a one dayer on April 28. then back again May 25 and 26 camping at Jellystone.
BTW - perfect choice on tires. I used to run 20" ten paddels - picked up 3 bike lengths in the 100yrd switching to 22" 8 paddle. I mean I ran both sets in the same day, against the same people, many times, for this true and accurate comparison.
Old Apr 8, 2004 | 12:17 AM
SANDMAN430's Avatar
i run 15-43 on my 720and i don't know what the top speed is but it is faster than i want to go on shaved bald tires i also run 22' and 23" rear tires, all i know there are lots of banshees left behind at those speeds, i personally don't like going that fast, i think it is in the 80-85 range. so if it would pull 17-40 in 5th gear the speed would blow you off the quad.
Old Apr 8, 2004 | 11:26 AM
SpinCycle's Avatar
Originally posted by: buttfungus
Originally posted by: MRDS650At least a 15 tooth. I would probably go to a 14 tooth with a stock bike. I ran a 14/40 combo with a fair few mods. The only problem is you will have to take a link out of the chain to make the 14 tooth work.
I didn't have to take a link out of my stock chain with the 14/40 combo??
I had no issues installing a 14t either...
Old Apr 11, 2004 | 12:02 AM
Dingo2's Avatar
Hightower..or any one else who has changed the rear engine mount around. I've tried everything to get that engine mount nut lose..everything from a breaker bar to an impact wrench..it wouldn't move!!!
Any other suggestions??
I'm gonna try the 14T front..will I have any problems with the chain rubbing that bolt? Thanks...
badgerboy1
Sep 26, 2017 06:11 PM
Dunes and Dune Machines
Sep 29, 2015 09:35 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
bigred20653
Sep 19, 2015 02:11 PM
TLC
Utility ATVs
Sep 16, 2015 01:41 PM
