do you believe this?
Old Apr 6, 2004 | 10:56 PM
01ds650's Avatar
Default do you believe this?
8% gain????
rectifier
BTW, there are CDI's on Ebay for $99.....
Old Apr 6, 2004 | 10:58 PM
1BigDSRider's Avatar
I have also seen this add on ebay. Has anyone bought one?
Old Apr 7, 2004 | 01:12 AM
Doctorturbo's Avatar
GOT BOOST!
Lets say 50HP stock. Or 54 with this gizmo on it (8% gain). I don't think it would take 4 HP to turn the charging circuit. So no, I don't think you will pick up 4HP or their 8% gain. 1/2 horse, or so, mmmmmmmm........ok, I would go for that, but it just does not take that much HP to maintain a battery at almost full charge. Maybe they dropped the voltage down to 5 volts and then made their pull on the dyno? [img]i/expressions/face-icon-small-happy.gif[/img]
Old Apr 7, 2004 | 06:13 PM
DSDuneCrazy's Avatar
In theory it should work. A stator does eat a little HP. I dunno about 8%, but it does eat some. But the results will vary depending on the current state of your battery at the time. Your ignition uses a little juice to run, so as soon as the battery drops down a bit, you will lose the gained hp. I would imagine if you are running your lights all the time, it may never show the increase in power.
Old Apr 7, 2004 | 07:10 PM
blue250r's Avatar
acording to the bomb book it says the ds produces 290 watts from its stator/altenator.
1 kw= 1.341 horsepower 1 watt = .001341 HP X 290 = 0.3889 HP
I think thats right
you would of course have to factor in losses due to genarator inificiancy ect. ie if it produces heat it wastes energy
but i still dont see it taking 4 hp to make 290 watts
so i would doubt there claims
but if you need a new one any way it might be a good deal
Old Apr 7, 2004 | 10:41 PM
duneittilludie's Avatar
I put one of the procom rectifiers on my wifes 440 ex and there was a noticeable difference in power but 8% seems like a bit of an exaggeration.We could tell a difference in the rate that her 440 went through rpms under a load up a sand hill so there was a performance increase .After seeing what the rectifier did for the wifes 440 i will probably be purchasing one for my baja.
Old Apr 8, 2004 | 12:19 AM
SANDMAN430's Avatar
8% seems like a lot. almost to good to be true.
Old Apr 8, 2004 | 12:26 AM
Haulinonthedunes's Avatar
If it sounds to good to be true it usally isnt true. [img]i/expressions/face-icon-small-smile.gif[/img] Lance
Old Apr 8, 2004 | 12:34 AM
XR650Warrior's Avatar
8% , no, I don't think so, .8% maybe[img]i/expressions/face-icon-small-smile.gif[/img][img]i/expressions/face-icon-small-wink.gif[/img][img]i/expressions/face-icon-small-confused.gif[/img]
Old Apr 8, 2004 | 01:35 AM
GOT BOOST!
For all of you people into this sort of thing. You can do the old drag racer thing and wire a simple switch into the field wire. When you race, switch open. When you are just tooling around, switch closed. For less than $5 bucks, you too can save a 1/2 a horse!!!!!!!!!!
