DS650 Weight Reduction!
Old Apr 9, 2004 | 11:32 AM
BillDS650's Avatar
Default DS650 Weight Reduction!
[img]i/expressions/face-icon-small-wink.gif[/img] So far I have removed 40 lbs from my DS650. I am now working on the next 37 lbs only going to cost me a little over $1000.00
Old Apr 9, 2004 | 12:01 PM
BAJAXPIMPN's Avatar
Me too! Thanks to abetter diet and portion control I've lost 40# fron Dec 8th!! My BajaX thanks me very much!! :-)
Old Apr 9, 2004 | 10:50 PM
ezwheeler's Avatar
how did you do it?i would like to put mine on a diet too.
Old Apr 9, 2004 | 11:04 PM
MudStud's Avatar
I removed 40lbs from mine also...
BillDS650's Avatar
I went on a diet. but the DS can lose some with TVI aluminum swing arm, TBR A-arms, RADmfg titanium rear axle. Alaba or CT pipe. 04 front engine mounts, remove air box, MRHP front hubs, change over to 520 chain, Fox new air shocks.
Old Apr 10, 2004 | 12:49 AM
SANDMAN430's Avatar
i'd like to know more about lighter shocks?
Old Apr 10, 2004 | 01:24 AM
VEGAS650's Avatar
Bill, are you running the 520 chain.
If so, tell me what I need to get to do it.
Al
Old Apr 10, 2004 | 09:28 AM
BillDS650's Avatar
AL If I get the RAD Axle I think it is set up for 250R sprocket Hub. The wheel hubs are eather Honda or Yahama. Just ned to get a front sprocket from BMW F650. I will Know more when I call next week.
Old Apr 10, 2004 | 10:23 AM
SANDMAN430's Avatar
so the bmw runs 520 front sprockets? side winder said they can get 520 rear sprockets but the weight wasn't that much different.
Old Apr 10, 2004 | 10:55 AM
BillDS650's Avatar
You can get rear Heat-Treated Chromoly Steel Nickel Plated Laser Cut
sprocket in 37 to 43 tooth for the 250R
