Big Question Cams In 2 Strokes
#21
#23
#25
put all the powervalves & reeds in your DS's you want. I'm putting new muffler bearings in.
they do exist
don't forget these!
they do exist
don't forget these!
#27
Originally posted by: Boomer84
Stihl ,has a 2 stroke that has valves,so change your thinking about how engines work!!!
#28
#29
the stihl is still a four stroke just not a conventional one. four strokes means there are four strokes intake,compression,power and exhaust. a four stroke takes two crank revolutions to complete a cycle and a two stroke only takes one. hope thats right and i haven't made myself look like a fool. the stihl is just using the same type of oiling system that two strokes use. their right about a two stroke being able to run upside down. we have some two stroke engines here in the plant called M.E.Ps that were used in ships and subs. we use them to turn compressors and they can run upside down. their some wierd looking engines that have two cranks, one on top and one on the bottom of the engines. don't know what MEP stands for but i've always heard multiple engine problems which fits them good.
#30
Lawnboy mowers claim to fame was their 2 stroke motors could run sideways on hills & such like. The problem is getting a lawnboy to start & if you do that stupid little front wheel lets it gouge every little bump! Most overated mowers ever! I'll take my MTD with my custom striper anyday!
