16:1 Piston for the Alcoholics
Old May 10, 2004 | 06:02 AM
  #21
SANDMAN430's Avatar
Default 16:1 Piston for the Alcoholics
two base gaskets? that is a much better idea, how much can you change things like that without doing anything to cam timing?
Old May 10, 2004 | 11:15 AM
  #22
SANDMAN430's Avatar
i've run with a few others that have worked the degree on there cams and it made a hugh difference
Old May 10, 2004 | 07:06 PM
  #23
Sandragggen's Avatar
just to clear things up .... the 14:1 piston does not run two head gaskets ..... it run's two base gaskets . [img]i/expressions/face-icon-small-smile.gif[/img]
Thanks for clearing that up. My bad.
JMiller
Old May 10, 2004 | 08:20 PM
  #24
DCryder's Avatar
Bartlett,
Do you have adjustable cam sprockets??? If so where did you get them.
Old May 11, 2004 | 09:53 PM
  #25
Doctorturbo's Avatar
GOT BOOST!
Hey BartlettRacing, or anybody else, have you seen any dyno runs between a "true" 14 to 1 and a "true" 16 to 1? Just wondered if there was any power difference between the two, and if so how much?
Old May 12, 2004 | 06:49 AM
  #26
Ward660R's Avatar
From what I can gather it should be about 2.5% per point of increase.
exmotocrosser
Sep 13, 2019 06:12 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
nastyblaster100
Sep 13, 2015 01:19 PM
