unstable at high speed
Old Jun 15, 2004 | 11:21 PM
riderrideshard's Avatar
Default unstable at high speed
when i am going down a back road or a trail at higher speeds the ds is very twitchy.what can i do to help the steering out?
Old Jun 15, 2004 | 11:23 PM
JMAC650's Avatar
Check your toe on the front end. You should be like 0" to 1/4" toe out on front when sitting on it.
Old Jun 15, 2004 | 11:33 PM
Air's Avatar
Air
Personally I run my DS @ 1/8 toe in with me on it. I have aligned cars for year and a Twitchy car is caused by toe out so I reasoned (right or wrong) that toe in would help the ds. I also run a steering stabilizer. I can let go of the handlebars @ wot in 5th with a 17 tooth front sprocket on it and it will go straight.
Old Jun 15, 2004 | 11:44 PM
bigben's Avatar
New a-arms is the permanent fix.
A friend of mine rode my DS this weekend and didn't like the steering, but I've ridden it enough that it doesn't bother me.
Old Jun 16, 2004 | 10:22 AM
SANDMAN430's Avatar
they said the front fenders were part of the cause to new riders on the bomb. align and you should get ride of the feeling
Old Jun 16, 2004 | 10:52 AM
sam's Avatar
sam
if you still got the stock Kendas trash them the make the front end twitchy too. put some thing taller on like the Ohtsa or Klaws.
Old Jun 16, 2004 | 01:51 PM
BigJon's Avatar
Graydon Proline steering stabalizer is a must.
It is like night and day....
Old Jun 16, 2004 | 03:01 PM
Billsner's Avatar
BigJon, i am always looking for new improvements to make, how does the s/s help?
Old Jun 16, 2004 | 03:29 PM
TexasPsycho's Avatar
mine is pretty bad at high speed too. i have adhusted the toe but am pretty sure it is the caster/camber adjustment,which i can't adjust. i can look at the front of mine and tell it is way off. the tops of the tires are leaning in really bad. new a-arms one day.
Old Jun 16, 2004 | 04:49 PM
BigJon's Avatar
the steering stabalizer makes the steering feel as though its in a track and smooths it out.
No more bumpiness. No more handlebars jerked from your hands if you hit a rock.
I was really suprised what a difference it made.
There is no way I would want to ride at high speeds anymore without it.
I also have replaced the upper a-arms on both of my DSs. That seemed to help a bit too.
Not as much as the stabalizer though.
2quiker
Mar 22, 2022 08:36 PM
mywifesquad
8
Sep 21, 2015 08:20 AM
Steeldon
Sep 9, 2015 09:38 AM
black_thunder
Sep 6, 2015 04:41 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
