dynojet kit for ds
dynojet kit for ds
i just put the kit in and rode it for a while then pulled the plug and it is as white as a new one.so i put the 185 jet in and moved the clip down to the 3rd groove and rode it again then pulled the plug and it still is very white on the porcilen. i checked for air leaks and found none. i am lost, it runs great but i dont want to burn it up. could someone help please.
dynojet kit for ds
You aren't going to see a lot of color on a modern 4-stroke. The fuel is pretty clean and it isn't like a two-stroke that has oil mixed in the fuel.
Really only one way to jet. Get the quad on a Dyno that has a fuel / air ratio meter and run it.
If there is a long steep hill near you and someone has a radar gun, you may also have some luck getting it dialed in.
CG400exMaster
09-25-2000 12:17 PM
