All Lectron 46 Owners I need help
Old 06-28-2004, 02:07 PM
huskerjim's Avatar
Default All Lectron 46 Owners I need help
Originally posted by: MisterHP
Husker,
Sounds like you have a Fast By Gast carb. Let me guess, it has a 2XL needle in it.
This dyno operator obviously knows nothing about tuning. If it is cutting out at 7k your rich. What was the air fuel ratio?
Sounds as if you both know your DS's I'm in Reno 4500 above Sea any suggestions on needle to start and I will have to look and see what needle is in it now it's at the shop. thx guys
Old 06-28-2004, 02:24 PM
MudStud's Avatar
Husker,Sounds like you have a Fast By Gast carb. Let me guess, it has a 2XL needle in it.
LMAO!!!
Old 06-28-2004, 02:49 PM
huskerjim's Avatar
LMAO!!!
Whats Fast By Gas mean guys?
Old 06-28-2004, 02:53 PM
MudStud's Avatar
MisterHP is the only person that sells the correct 46HV.. Fast only sells the regular 46. It is NOT the same as the 46HV carb sold. Dramatic power differance. I have the 46HV and it rocks. The big discusion in the past was that FBG could do it just as good.. So I find it funney.
  #15
Old 06-28-2004, 02:59 PM
CountryJoeGlass's Avatar
Huskerjim where did you get the 46 lectron carb?
  #16
Old 06-28-2004, 06:58 PM
MrHorsepower's Avatar
Pro Rider - Oldham Racing
BUILDS THE FASTEST DS's ON THE PLANET!
Want a hot DS, or maybe one of the fastest DS's on the planet? This is the man to contact!
Are you running a clamp on filter? If so pull it off and slip the snorkel tube back on, this will lean out the air fuel ratio some but probably not enough.
That engine combo should be making 60hp.
  #17
Old 06-28-2004, 08:59 PM
sixsixT's Avatar
If you want some more input on your output you need to give some more input or your output may not change.[img]i/expressions/face-icon-small-wink.gif[/img]
  #18
Old 06-29-2004, 12:57 AM
huskerjim's Avatar
Guys I'm so wore out I'm smooth right now...
How do I know which 46 I have, I bought it from a guy named Eric
Ok OK I got the paper work in frt of me it says it is an Lectron 46mm Custom High Velocity single power jet it has an pinned independent
floats left side fuel deliery choke 25 power jet bleed air circuit pressure relief slide the needle 1-5, I will be willing to pay someone who is capable to set this darn thing up in Reno, HELp any suggestion HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  #19
Old 06-29-2004, 01:07 AM
Entomber's Avatar
Husker,
I strongly suggest you package it up and ship it over to MRHP. He will prob (I can't speak for him) turn it around faster than you can find someone out there. He'll set it up for you. He did for mine and now my DS has really woken up. He is well worth the $$.
  #20
Old 06-29-2004, 01:19 AM
BigDaddy331's Avatar
guy named Eric [img]i/expressions/face-icon-small-shocked.gif[/img]
looks like someone might be on the sucker train again. Glad it's not me this time. I've learned to keep my mouth shut! [img]i/expressions/face-icon-small-cool.gif[/img]
Husker, you should probably get your carb shipped out to the REAL Eric. Just so that you know, the Lectron 46 was NEVER meant to run on anything that can be trail ridden. It is a drag racing carb that Mr. HP (the REAL Eric) put lots of time into to get it to run on the DS. How do I know all this? [img]i/expressions/face-icon-small-happy.gif[/img]
Where should I start guys?
Husker, just trust me.........
good luck.
BigDaddy
Quick Reply: All Lectron 46 Owners I need help
