Oil in airbox, lots of oil but runs great, gargles
Hello All!
I am hoping you can help me out here. My atv has always lost a little oil into the airbox, but this past weekend it lost a ton. Perhaps 1\2 a quart or so. I mean I was on some hilly terrain but that's ridiculous. The oil level was fine when i started, it was not overfull as it had just been changed (tank and all).
When I shut off the atv is gargles, sounds like oil rushing into the tank? Is this normal? I never noticed it before but think i am getting paranoid.
I think I might start off with a compression test to see if I am having blowby problems, but the atv is running great, stronger then it ever has before. Would I notice a performance decrease with it if i was getting enough blowby to lose that much oil?
Anything else I should check for?
Thanks,
Jim
Thanks,
Jim
I ride wheelies for long distances and had no trouble with oil in the air box so I dont think its from hills. Do you think you might have over filled it during a oil change or some thing, and its just pushing the excess out? have you ran it since? what does the dip stick reflect now does it show its low?
it has two oil pumps - supply sucking from tank and pumping through oil filter, and a return pulling from crankcase and sending oil back to tank.
piston blowby pushes oil out the breather yes, but only 30 hours - it sure shouldn't be blowing by like that, but hey anything's possible...
return pump failure would cause too much oil to be present in crankcase and an excess blown out, but that's awefully unlikely, I've never heard of oil pump problems yet anyway...
are you sure you didn't roll the bike? you'd defenitely get a big cough up of oil if so...
Make sure that thier is no kinks in your breather hose, This will biuld up alot of crank pressure, then when you stop it will puke oil. If the problem continuos then you probably need to take it to your dealer. It sounds like the quad is still under warranty. Make sure you tell them that this is unacceptable out of a NEW, NON-MODIFIED quad.
bigger.
bigger.
