speedo
Old Jul 14, 2004 | 06:08 PM
rykid's Avatar
Default speedo
where can you get the handlebar clamp to hold it?? and how much
Old Jul 14, 2004 | 06:11 PM
shmee's Avatar
Default speedo
hey rykid do you still need the nurf bars?? ill work a little more with it.
Old Jul 14, 2004 | 06:52 PM
BigWaynester's Avatar
Default speedo
What kind of speedo is it?
Old Jul 14, 2004 | 07:10 PM
rykid's Avatar
Default speedo
same as yours bit the handlebar mount like u said u should have gotten
Old Jul 14, 2004 | 07:44 PM
busmechanic's Avatar
Default speedo
I have the handle bar mount. you have to buy a replacement cable/sensor. since it is one peice. I got mine through rockymountainatv.com you can also get them right from trail tech. they are in washougal washington. not sure if they have a web site though. I will see if I still have the number.
Old Jul 14, 2004 | 07:45 PM
Default speedo
The handlebar mount should come with the speedo.
Old Jul 14, 2004 | 07:47 PM
Default speedo
here is there site. there in battle ground, wa.
Old Jul 15, 2004 | 01:45 PM
rykid's Avatar
Default speedo
if i do go and order the trail tech speedo does it come with everything i need to make it work then? and is it simple to put on?
Old Jul 15, 2004 | 07:32 PM
Default speedo
easy to install. you take off a front hub. drill a hole in the steering knukle. epoxy a small magnet in the brake rotor. and yes , it comes with everything you need. unless you want the billet handlebar clamp mount. thats extra$$$$$$$
speedbuff
13
Nov 11, 2020 10:16 AM
black_thunder
Sep 20, 2015 10:21 PM
Adrian Turner
Aug 30, 2015 04:08 PM
bradco
Aug 21, 2015 08:11 PM
Xpedtion4254x4
Dec 20, 2000 12:58 PM
