stage 2 now what next?????
Old Jul 20, 2004 | 03:44 PM
shmee's Avatar
Default stage 2 now what next?????
always looking for more power!!!![img]i/expressions/face-icon-small-smile.gif[/img] what would be the next step??? im thinking of doing a stage 3 but while i was reading the bigger valves dont help. just p & p. what has everyone else done other than big bore. and same cams the a1.
Old Jul 20, 2004 | 03:46 PM
shmee's Avatar
does porting and polishing help that much if you do it right. may be 3 bike links.
Old Jul 20, 2004 | 03:56 PM
DuneMe's Avatar
The larger valves and porting do help.
You may want to look into a 730 though since you are probably looking at about the same price for that set-up.
I've found a carb mounted K&N will give you about 3HP vs. in the box K&N. If you are just looking for a couple extra lengths that may be the ticket.
Old Jul 20, 2004 | 03:58 PM
shmee's Avatar
i was going to buy the valves from ron w and install myself and p & p myself. the machine shop will put valve seats in. i will need to do this anyway if i go big bore right.
Old Jul 20, 2004 | 04:21 PM
sam's Avatar
sam
what about NOS ????
Old Jul 20, 2004 | 04:22 PM
shmee's Avatar
i want the power all the time.
Old Jul 20, 2004 | 05:13 PM
dwslim's Avatar
HEY Sam,
Did you fab up your fender supports?
Slim
Old Jul 20, 2004 | 10:31 PM
crazypainter's Avatar
the ported head with bigger valves pulls very hard in the upper rpm range as I think youll admit even with the pitiful stock carb, pipe and air filter. still pulls like a raped ape. John
Old Jul 20, 2004 | 11:28 PM
sam's Avatar
sam
Yes, 3/8 rod W/ tabs welded on. I tried aluminum But upon a landing one time a little crooked... ok really crooked I bent them really bad and they snaped, so I went to the 3/8 rod and painted them. Most you see on my quad is custom one offs. I used to be the only one w/ the 5" end cap but a couple cought on and built there own.
Sam
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
Elkaholic
Sep 6, 2015 02:44 PM
Backwoods_badass
Aug 28, 2015 12:35 AM
Backwoods_badass
Aug 27, 2015 11:23 PM
Huntingdeer
Aug 23, 2015 12:06 AM
