Engine Noise
Old Jul 28, 2004 | 04:22 PM
marrtoo's Avatar
Default Engine Noise
To low octane gas or what the others said or the hearing aid might need turned down a bit[img]i/expressions/face-icon-small-happy.gif[/img]
marrtoo
Old Jul 29, 2004 | 12:44 PM
rykid's Avatar
i notice that the plastics that touch the fog lights make noise i was thinking about putting some foam there to stop it gets loud sometimes
Old Jul 29, 2004 | 01:42 PM
DuneRider650's Avatar
I ride a little here and there......
i just seen that to the other day when i was checking around and was thinking about putting something under there also
Old Jul 29, 2004 | 02:20 PM
jdub260's Avatar
I had this same problem but after I changed the Silencer it was still there so I look further. I found that if I bent the metal around the baja lights out away from the brackets that hold the light it stopped the rattle. You might try this.
Old Jul 30, 2004 | 12:35 AM
  #15
04scramblerdude's Avatar
I doubt anythings wrong with it im sure its just the engine vibration against the frame. Cause they dont have any rubber motor mounts on them i wouldnt worry.
Old Jul 30, 2004 | 12:38 AM
  #16
alright guys thx allot for helping me find out what it was it turned out it was the baja lights in the front the plastic was rubbing on the top of them so i bent them down a tiny bit and tightened up the light bolts they were a bit loose to and its all smooth now.
Old Jul 30, 2004 | 05:49 PM
  #17
rykid's Avatar
[img]i/expressions/face-icon-small-smile.gif[/img] knew it
greg74
Sep 10, 2019 03:03 PM
ronnierhino06
Nov 9, 2015 12:56 PM
hondarider1234
Jul 21, 2015 11:53 PM
ghost civic
Jul 19, 2015 10:13 AM
D-Hagz
Jul 4, 2015 02:19 AM
