ANY IDEAS?? PLEASE HELP!
Old Aug 1, 2004 | 05:30 PM
RickyD650's Avatar
Default ANY IDEAS?? PLEASE HELP!
HELLO, i JUST GOT MY DS ABOUT A WEEK AGO AND I WAS DOINA COMPLETE RUN THROUGH OF THE MOTOR ALSO CHANGING THE OIL AND BRAKE FLUID. HOWEVER WHAT I DID NOT RELIZE WHEN I BOUGHT IT WAS THAT ON THE HANDLE BAR THE BRAKE FLUID CASE THE 2 SCREWS R COMPLETELY STRIPPED. I TRIED PUTTING PENATRATING OIL ON THEM BUT THAT DOSE NOPT SEEM TO BE WORKING I THINK THE LAST PERSON WHO HAD THIS QUAD HAD AIR TOOLS BECAUSE EVERYTHINGH IS EXTREAMLY TIGHT. ANY WAY IF U HAVE ANY IDEAS ON HOW TO GET THOSE SCREWS OUT PLEASE HELP ME IT WOULD BE GREATLY APPRIECATED. THANK YOU
Old Aug 1, 2004 | 06:16 PM
tacookaz's Avatar
Try an easy out bolt remover. Kinda looks like a tap but the cutting edge is spiral left hand thread.
Othewise, time to drill!
Good luck
Old Aug 1, 2004 | 06:18 PM
RickyD650's Avatar
THANX BUT WHERE CAN I GET THIS "EASY OUT BOLT REMOVER" AND ALSO HAVE U EVER USED IT OR KNOW SOMEONE WHO HAS DID IT WORK? THANX
Old Aug 1, 2004 | 07:30 PM
DuneMe's Avatar
Everything on the bike should be tight. If not, vibration will take it out. Use Locktite when you put things together or you will find yourself missing some bolts.
Old Aug 1, 2004 | 10:24 PM
BlackHawk's Avatar
Bombardier makes ALL bolts from the factory -VERY- tight. You are probably looking at factory tightened bolts.
Old Aug 1, 2004 | 10:59 PM
DiSideup's Avatar
Try cuting a notch in the head of the alen bolt and use a flat blade srewdriver
fordfaithful21
Dec 7, 2015 05:52 PM
PrairieDog126
Sep 12, 2015 06:53 PM
Elkaholic
Sep 6, 2015 02:44 PM
toonces
Sep 5, 2015 01:14 PM
