Stupid fan question.
Old Aug 29, 2004 | 07:43 PM
MudStud's Avatar
Default Stupid fan question.
I cut the wire to the fan and ran a wire straight to the hot on the battery and another to a ground. I put the BLUE wire to hot and BLACK to ground.. The fan did NOT even move.. I assume the fan is dead...
Best place to get a fan.. I looked in the past but the links are dead..
Old Aug 30, 2004 | 02:25 AM
BigWaynester's Avatar
fanthis is where I got my fan. Let us know if you find a better price. There is usually on on ebay.
Old Aug 30, 2004 | 04:01 AM
BlackHawk's Avatar
I got my fan from offroad warehouse and I paid a little more but I did also get a waterproof one (just in case it gets splashed or something.) That $61.99 price is VERYappealing though, I've never seen one so cheap.
Old Aug 30, 2004 | 09:44 AM
SANDMAN430's Avatar
i paid 175 for a bomb one that is a little marked up i think.
Old Aug 30, 2004 | 09:58 AM
MudStud's Avatar
If I just get the puller will that be all I need? That bolts right up and the heat shield goes rigth on?
Old Aug 30, 2004 | 10:01 AM
MudStud's Avatar
Do I need the heet shield with the spal fans?? Do they hook up exactly the same? mounting to the quad I mean?
Old Aug 30, 2004 | 10:04 AM
MudStud's Avatar
OOO.. Water proof fan I just found it on OW site!! Sweet!! Its mine! Do I need JUST the fan? no other items?
Old Aug 30, 2004 | 10:15 AM
DSaholic's Avatar
Yes just the fan the heat shield will bolt right on the that new fan you just have to replace the screws that come on the fan with the ones on the old fan that hold the shield on.
Old Aug 30, 2004 | 10:41 AM
JWALK1's Avatar
Take the fan off to test if dead or not. It is VERY easy for the fan shroud to become distorted and bind the fan not allowing it to spin which over time will burn up the motor.
Happened to me and my buddy.
Old Aug 30, 2004 | 11:19 AM
You may notice some shims behind the old fan when you take it off. When you put the new fan on, shim where needed so the fan fits flat. You need to put the shield back on the new fan, so save the screws and spacers and shield before you toss your old fan.
bigred20653
Oct 2, 2015 10:05 AM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Bigtwin700
Sep 9, 2015 09:32 AM
GODsRebel
1) Engine problems..
11
Sep 8, 2015 12:07 AM
Atvnewb88
Aug 13, 2015 06:48 AM
