Oil Switch Again - How Much $$$
Originally posted by: BajaXRider04
JMAC650,
Is it difficult to see your tach with the rollDesign steering stem and handle bars, they look highter?
I think I would like higher if they didnt block the tach.
How does the stem improve handling?
I know the handling between the older model ds and the new ones is a night and day difference,
buts is that from the A arms up front or the stearing stem?
JMAC650,
This might be a stupid question but how do you know if your oil sensor is bad...just by looking at the red light when you start the bike? If your riding, the light goes out..so how do you know its bad if it goes out during a ride?
The boot just fits snugly over the sensor and there is some silicone and a wire tie keeping it secure on one end and water tight.
#15
I called my dealer today; there's a bulletin (2004-3) which addresses the boot for the oil sensor connector. No warranty, a service bulletin. Anyway, the rubber boot is $3 and the sensor is $13. Taking a look at the temperature sensor, I'm assuming the rubber boot similar.
The parts had to be ordered and won't be in until Tuesday. I'm riding this Sat and the light is on. Should I ride this weekend?
#16
OZ,
I rode mine some with the red light glowing dimly, but after some riding it would heat up and it would go out.
It’s like riding blind with no safety net if your temp/ oil light isn’t working properly. Do ya Feel Lucky, Punk..... [img]i/expressions/face-icon-small-smile.gif[/img]
Isn’t there another dealer on your way there that you could call to see if they might have a sensor? (Just keep it dry until your boot comes in.)
kbazzy
Sep 26, 2015 11:26 AM
