Modified encap jetting
Old Sep 13, 2004 | 02:07 AM
DuneRider650's Avatar
I ride a little here and there......
Default Modified encap jetting
hey all tommorow im gonna cut off my spark arrestor and the tubes on the inside to where they go small then put it back on, will i have to rejet. Will my quad go lean or rich when i do this. Im alrdy running a bit lean i think.
Old Sep 13, 2004 | 04:01 AM
busmechanic's Avatar
I ran a fmf .180 main jet. fmf needle on 2 groove from top. 3 1/2 turns out on air/fuel screw. lid on air box when I had the same moded end cap as you desrcibe. if mikuni jets are used. you probably want to use .170 to .175 main jet and needle on last groove from top. I think there is a recent thread for jetting that should suit your needs. I am talking 0-3000 feet.
Old Sep 13, 2004 | 01:14 PM
ok thanks for the help, im gonna cut em off when i get home from school then i will see wont change jets prob just move the clip
Old Sep 14, 2004 | 08:38 PM
cain73's Avatar
I also have a modified end cap that I bought off of ebay. I rejetted to a 175 Mikuni (instead of the stock 165) and it seems like my DS is running a little hotter. Could this be due to the jetting being a little lean? It pulls great all the way to the limiter, but I was wondering if (at 50 above sea level) I should try a 177.5 or a 180. but would rather not take it apart and go through changing jets again if it's not going to help. Any thoughts?
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
