DS Guy's Opinion on the TRX450R ........
Raidermike ... If you reduce a tooth on the sprocket, which is done by purchasing a new one, you will change the gearing.
The following statements are made with the assumption that there is plenty of horsepower and there is no change to tire sizes..... and Im not splitting hairs in the explination Im just trying to give you a quick explination as to what will happen.
ADDING an extra tooth to the front sprocket will increase your top speed but will take a little longer to get to that top speed...
REMOVING a tooth on the front sprocket will decrease your top speed but you will quickly get to that top speed.....
The opposite is true when you do these changes to the REAR sprocket. The difference being you have finer control to the gearing when changing one tooth at a time on the rear. remeber , Just like Maddog56 just stated 1 front tooth = 3 or 4 teeth on the rear.
Clear as mud????
Clear as mud????
#16
braap123
09-07-2015 12:58 PM
braap123
09-07-2015 10:57 AM
