Slow oil leak at drain plug
Old Sep 21, 2004 | 02:01 PM
DSengineer's Avatar
Has been here a long time!
Default Slow oil leak at drain plug
I have been finding small drops of oil in my garage where I park by DS. I got up under it last week and noticed a drop of oil hanging from the drain plug ready to fall. I though the bolt might be loose so I put a socket on it and tried to snug it but it was already tight. I loosened it and re-torqued. It is a week later and I still have the slow leak (1-2 drops a day). Any ideas on whats going on?
Old Sep 21, 2004 | 02:21 PM
05DS650X's Avatar
I believe the little washer on the drain plug is actually a gasket. The manual says to change the gasket on the drain plug when changing the oil. Maybe it is in need of replacing. Just a thought.
Old Sep 21, 2004 | 03:04 PM
Majorecho's Avatar
should have an aluminium crush washer there, order a new and replace it, they can get messed up after multiple oil changes and start to leak.
Old Sep 21, 2004 | 03:11 PM
DSengineer's Avatar
Thanks,
I was thinking possibly the crush washer, but I have only changed the oil once since I bought it. I will go ahead and replace anyway on my next oil change to see if it stops the leak.
How often do you guys replace your crush washers? Every oil change?
Old Sep 21, 2004 | 06:46 PM
DuneMe's Avatar
I've never had to replace mine but, a small amount of sand could have got in there or, it may have fallen out and you didn't notice [img]i/expressions/face-icon-small-blush.gif[/img]
Don't over torque it. You can strip the treads on the drain plug. Check out the F650faq web site and you'll find this as a common issue.
Old Sep 21, 2004 | 06:55 PM
NickDS650's Avatar
Yea same thing happend to me, ordered a new plug and washer piece becuase i over torqued it and bent the plug threads, such a pain for a lil thing lol
slowgsxr97
Mar 18, 2022 03:40 AM
SDR-II
Sep 29, 2015 01:06 AM
Captjay
Jul 23, 2015 12:33 PM
Unzzy66
Jul 11, 2015 10:01 PM
Shifts
Jul 3, 2015 07:59 AM
