good place to wire in lighted whip
Old Oct 4, 2004 | 09:17 PM
Hez's Avatar
Hez
Default good place to wire in lighted whip
does anyone have a nice place to wire in my lighted flag whip? should i just tap in at the tail light? (not brake light of course).
Thanks,
Hez
Old Oct 4, 2004 | 10:09 PM
busmechanic's Avatar
how about running a whole new circuit. just run a lead off the batt. fused within a couple inchs of course. then run a relay with a switch. so you can just turn it off or on. or you could just run the coil side of the relay to a ignition source so it just comes on when you turn the key switch on. you might overlaod the tail light circuit if you run it off that.
Old Oct 4, 2004 | 11:36 PM
BlackHawk's Avatar
The tail light running light circuit has enough to power an extra 1156 bulb; I've been doing it for quite some time now on both of my DS650s with no issues. I've run both an 1156 and a 1156 LED bulb so there should be no isses. If you wire it to the battery, put an inline fuse - you never know when that fuse will make you happy.
As far as where to get them, I dunno for sure; I use a buggy whip which is very stiff and certainly not for everybody. You might be best to buy one at a local shop. I bought my whips at Prowlers, I know they do mail order so if you can't find them locally that is an option. They are just down the street from me.
Old Oct 4, 2004 | 11:55 PM
crazypainter's Avatar
on my whip I wired an 1157 into the tailight that way i can have the key on and park brake set and I've got light without the headlight drawing my battery down. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Oct 5, 2004 | 12:26 AM
Hez's Avatar
Hez
this gives me some ideas.....thanks guys!
FWhitt
Jun 13, 2015 02:22 PM
hoopduerr
Jun 2, 2015 09:01 AM
hoopduerr
Jun 1, 2015 08:22 PM
neilbedwell
May 29, 2015 02:24 PM
lordmik
Mar 9, 2000 01:20 AM
