trail riding sprocket setup
Old Oct 6, 2004 | 11:43 PM
DSBS's Avatar
Default trail riding sprocket setup
I do a lot of trail riding and i was wondering if the stock sprocket setup is the best setup
Old Oct 7, 2004 | 12:04 AM
Prozack's Avatar
The Stock set up is a fine combo and will take on just about everything. Do you go hard and fast on the trails or are ya more of a "take your time and see the sights" kind of rider ?
It all depends on you and what the trails are like. If I were riding in rocky beds I would probably gear down so i could rock crawl a little better, Try a 15 tooth for that.
If you run sand washes and long bending trails try a 17 tooth. These are just a few recomendations.
Old Oct 7, 2004 | 12:48 AM
Coyoteman's Avatar
If you trailride and have the stock 20" rears try a 15 tooth front sprocket, more bottom end. If you have 22" rears go with a 14 tooth front. Thats what I run. Just snap the throttle and bring the front end up to go over logs, ditches and other obstacles. Good power for hills too.
Old Oct 7, 2004 | 07:53 PM
DSBS's Avatar
I am running 22'' rear and i ride hard and fast in prity rough rocky ''Baja'' terrain
Old Oct 8, 2004 | 12:59 AM
Coyoteman's Avatar
Get both the 14 and 15 tooth sprockets. They're not very expensive and they're easy to change. Then you could change gearing at any time.
Frisky2050
Apr 9, 2020 11:19 AM
buckshit
Sep 24, 2015 08:49 PM
sara durrant
Jul 6, 2015 05:32 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
cva81
Club News and Events
May 25, 2015 08:23 PM
