Handgards for Trailtech X bars
Old Oct 23, 2004 | 06:26 PM
Camds650's Avatar
Default Handgards for Trailtech X bars
Does any one know what if any handgards will work with the trailtech X bars?
Thanks
Old Oct 23, 2004 | 08:04 PM
ckedd's Avatar
Thanks
I have trailttech bars and us these grips. they look great and are easy to put on
Grips ODI Rogue 90mm 3/4
Use the 90mm ones and the Rogue. I have the billet end caps also. hope that helps
ckedd
Old Oct 24, 2004 | 12:59 PM
DSengineer's Avatar
Has been here a long time!
Thanks
There was a topic last week on handlebars where someone said an adapter kit was needed from Trailtech to use the stock Baja handguards. You may want to contact Trailtech to inquire.
Old Oct 24, 2004 | 01:41 PM
DSengineer's Avatar
Cam,
This is the thread I had seen in regards to mounting the Baja hanguards on the Trailtech bars:
http://forums.atvconnection.com/mess...ord1=trailtech
Old Oct 24, 2004 | 04:14 PM
Hightower's Avatar
Aren't the TrailTech's the same diameter and taper as all the other fat bars? I would think that any adapter kit for any of the fat bars out there otta work. But call like DSengineer suggests.
Old Oct 25, 2004 | 01:57 PM
Camds650's Avatar
Below is the reply from Trailtech
Kelly from Trailtech
"Pro Taper style aluminum wrap around hand guards are good (we have used Enduro Engineering guards). The bolts that go in the ends seem to vary in size, and we have on occasion had to drill the ends out by a couple of millimeters for good fit. We also have some bars here with larger diameter bar end holes for people who specifically ask for bars to go with aluminum wrap around hand guards"
Valder
Nov 28, 2020 07:38 AM
wendal
Sep 7, 2019 06:46 AM
badgerboy1
Sep 26, 2017 06:11 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
PrairieDog126
Sep 12, 2015 05:23 PM
