chain roller
Old Nov 1, 2004 | 02:50 AM
Hez's Avatar
Hez
Default chain roller
What does it sound like when your chain roller is bad? Im getting some weird griding sounds under load at low speeds and it sounds like its coming from the chain but not sure.
Old Nov 1, 2004 | 08:46 AM
BajaIowa's Avatar
I don't know what it sounds like when the roller goes bad, but if you are hearing sounds from the back make sure to check your carrier bearings. They will make some grinding noises until they lock up.
Justin
Old Nov 1, 2004 | 12:42 PM
Hez's Avatar
Hez
Its a brand new quad it shouldn't be the bearings, but it sounded like something kinda slapping something else, not very loud though
Old Nov 1, 2004 | 09:19 PM
BajaIowa's Avatar
That just sounds like normal chain slap. That is normal at slow speeds, just make sure the chain is adjusted properly.
Justin
Old Nov 1, 2004 | 09:29 PM
lilnotts's Avatar
i see you have a proarmorskid for the swingarm, i bet its rubbing on the piece of plastic on it, mine does that too at real slow speeds
Old Nov 2, 2004 | 12:35 AM
OregonDunePatrol's Avatar
All you need to do is inspect your chain roller. If it looks good, and your chain is properly adjusted, its ok. The newer model DS's have a hard plastic chain roller, that still makes noise (a very common problem; especially when you have paddles on a hard surface). There are durable chain rollers out there that are softer than the stock ones, but yet still hold up. They are much quieter than the stock one.
Old Nov 2, 2004 | 02:19 AM
R00ST's Avatar
ya if you have the skid as lil said, its quite noisy (kinda ticked me off, but i dont notice it anymore)
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
merryman
Sep 19, 2015 03:15 AM
bvolks
Sep 13, 2015 12:57 PM
bmark0610
Sep 7, 2015 09:42 PM
